The EVGA GeForce RTX™ 3090 Ti is colossally powerful in every way imaginable, giving you a whole new tier of performance at 8K resolution. It's powered by the NVIDIA Ampere architecture, which doubles down on ray tracing and AI performance with enhanced RT Cores, Tensor Cores, and new streaming multiprocessors. Combined with the latest cooling solutions including Vapor Chamber heat plate, 3.5 slot cooling and full control with EVGA Precision X1 software, the EVGA GeForce RTX™ 3090 Ti FTW3 Series redefines the definition of ultimate performance.
Designed for the most demanding gamers, content creators and data scientists, the EVGA GeForce RTX™ 3090 Ti FTW3 Series features a record-breaking 10,752 CUDA cores, and boasts 78 RT-TFLOPs, 40 Shader-TFLOPs and 320 Tensor-TFLOPs of power. And it's packed with 24GB of the fastest 21Gbps GDDR6X memory, providing 1TB/s of memory bandwidth.
2nd generation
rt cores
2X THROUGHPUT
3RD GENERATION
TENSOR CORES
UP TO 2X THROUGHPUT
NEW
SM
2X FP32 THROUGHPUT
Only On GeForce RTX™
The World's
Fastest GPUs
NVIDIA Ampere Architecture
MOST REALISTIC &
IMMERSIVE GRAPHICS
2nd Gen Ray Tracing
AI-ACCELERATED
PERFORMANCE
NVIDIA DLSS
Lowest
System Latency
NVIDIA Reflex
THE BEST EXPERIENCE
FOR EVERY GAME
Game Ready Drivers
BUILT FOR
LIVE STREAMING
NVIDIA Encoder
AI-ENHANCED
VOICE & VIDEO
NVIDIA Broadcast App
FAST-TRACK
YOUR CREATIVITY
NVIDIA Studio
FREE eLeash*
with EVGA GeForce RTX™ 3090 Ti FTW3 Series
With eLeash* Your Graphics Card is Always at the Right Position.
Click to learn more.
EVGA GeForce RTX™ 3090 Ti FTW3 Series Features
A newly-designed heatsink with Vapor Chamber heat plate spreads heat in two dimensions. As the GPU gets hotter, liquid in the vapor chamber is vaporized and spreads throughout the chamber through micro-thin heatpipes to maximize cooling efficiency. As the GPU cools down, the vapor returns to a liquid state and the process starts again.
Rigid Die Cast Backplate with Heatpipe not only secure your graphics card during operation and shipping, with building eLeash* notch to keep your EVGA GeForce RTX™ 3090 Ti FTW3 at the right position.
Incredible performance demands incredible cooling. The EVGA GeForce RTX™ 3090 Ti FTW3 Series features a 27% larger heat dissipation area.
The Hydrodynamic Bearing 2.0 (HDB) fan motor on the EVGA GeForce RTX™ 3090 Ti FTW3 Series feature an optimized 0dB mode under low loads and asynchronous fan operation. In addition, a special raised “E” pattern on fan blades reduce airflow noise under normal operation.
EVGA GeForce RTX™ 3090 Ti FTW3 Series Exploded View
1 | |
2 | |
3 | |
4 | |
5 | |
6 | |
7 |
