Header
XR1 lite
The EVGA XR1 lite capture card allows you to capture every epic gameplay moment - Record at 1080p/60fps while you game at 4K/60fps. The new compact design and USB 3.0 are perfect for capturing gameplay or connect it to a DSLR camera for a high-quality webcam option.
For Game Streamers
Instantly capture and stream every moment every win of your game play
For Working Professionals
Connect a camera to set up web conference, meetings, lectures, or seminars for higher video quality
OBS
Certified for OBS
The EVGA XR1 lite is certified for OBS™. OBS™ is a free and open source software for video recording and live streaming. Download and start streaming quickly and easily.
XR1 lite capture device
Specification
  • Interface: USB 3.0 Type-C
  • Input & Output Interface: HDMI
  • Video Input Resolution: 480p / 576p / 720p / 1080p / 2160p @60fps
  • Video Passthrough Resolution: 480p / 576p / 720p / 1080p / 2160p @60fps
  • Max. Capture Resolution: 1080p @60fps
  • Video Format: RAW
  • Dimensions: 100mm x 73mm x 15.6mm (L x W x H)
  • Weight: 75g
Features
  • 1080p @60fps Video Capture
  • 4K @60fps Input / Passthrough
  • Certified for OBS™
XR1 lite
Products
XR1 lite
