The EVGA GeForce RTXᐪᔿ 3060 Ti Graphics Cards have arrived.
The GeForce RTX™ 3060 Ti lets you take on the latest games using the power of Ampere—NVIDIA’s 2nd generation RTX architecture. Get incredible performance with enhanced Ray Tracing Cores and Tensor Cores, new streaming multiprocessors, and high-speed G6 memory.
Combined with the next generation of design, cooling, and overclocking with EVGA Precision X1, the EVGA GeForce RTXᐪᔿ 3060 Ti Series redefines what it means to have The Ultimate Play.
The all-new NVIDIA Ampere architecture features new 2nd generation Ray Tracing Cores and 3rd generation Tensor Cores with greater throughput. The NVIDIA Ampere streaming multiprocessors are the building blocks for the world’s fastest, most efficient GPU for gamers and creators.
2nd generation
rt cores
2X THROUGHPUT
3RD GENERATION
TENSOR CORES
UP TO 2X THROUGHPUT
NEW
SM
2X FP32 THROUGHPUT
PICK THE GRAPHICS CARD THAT FITS YOU PERFECTLY
EVGA GeForce RTXᐪᔿ 3060 Ti cards come in different sizes and offer different cooling solutions. From the redesigned iCX3 cooling assembly on the FTW3, to a shorter PCB and dual-slot cooling on the XC models, there's something for everyone trying to build that perfect system.
FTW3
XC
EVGA GeForce RTXᐪᔿ 3060 Ti FTW3
The EVGA GeForce RTXᐪᔿ 3060 Ti FTW3 cards are designed for the gamer who demands a screaming-fast card, ice-cold three-fan cooling, an all-metal backplate*, and attractive ARGB lighting. The FTW3 cards also feature iCX3 Cooling to provide a unified copper block for GPU and memory, a thicker heatsink to provide exceptional cooling, three fans to cool the card efficiently and quietly, and a 2-slot bracket to ensure case compatibility.
EVGA GeForce RTXᐪᔿ 3060 Ti XC
The EVGA GeForce RTXᐪᔿ 3060 Ti XC cards are designed for the no-frills gamer who needs a high-performance card that can also fit into tight spaces. Smartly designed to be cooled with two large fans, protected with an all-metal backplate, and carefully packaged into a short two-slot card for maximum compatibility with all types of gaming cases, the EVGA GeForce RTX™ 3060 Ti XC cards embody what it means to have The Ultimate Play.
