The SuperNOVA G+ PSU
Enter the SuperNOVA G+, the new and improved fully-modular power supply line-up from EVGA with an 80+ Gold Efficiency rating. These power supplies pick up where the award-winning EVGA 1600 G2 and 1300 G2 power supplies left off and continue the tradition of EVGA quality and performance.
Additionally, the SuperNOVA G+ power supplies feature a cleaner internal layout to increase airflow, a Variable Resistor module (to increase voltage stability), two DC to DC modules for more efficient power switching on all models, EVGA ECO Mode, a full suite of power supply protections, and EVGA’s World-Leading Global 10-Year Warranty on all G+ power supplies.
Shorter Length
1600 G+
(200x150x86mm)
vs.
vs.
1600 G2
(220x150x86mm)
When it comes to building a system, even the smallest differences can make or break your build. The 1600 G+ power supplies are 20mm shorter than their G2 counterparts, giving you more space without sacrificing quality.
Quiet and Long-Lasting Fans
1600 G+ - 135mm Double
Ball Bearing Fan
1300 G+ - 135mm Fluid
Dynamic Bearing Fan
Double Ball Bearings are the industry standard for any power supply expected to carry heavy loads on a regular basis due to their durability and low noise level. Fluid Dynamic Bearings reduce the wear and tear on a fan’s bearing, which reduces noise and increases its lifespan.
1600 G+
0.60%
vs.
1600 G2
0.83%
Tighter 12v Load Regulation
1300 G+
0.61%
vs.
1300 G2
1.98%
(Lower is Better)
The SuperNOVA G+ is loaded in many areas, including a single 12v. rail, 100% Japanese capacitors, VR module, and DC to DC converter on all SuperNOVA G+ power supplies. Compliant with IEC 62368*, this results in over 90% efficiency, 0.60%-0.61% 12v. load regulation, and stable power to all connected devices.
*1600/1300 G+ power supplies manufactured in or after 2020 are compliant with IEC 62368. 1600/1300 G+ power supplies manufactured prior to 2020 are compliant with IEC 60950.
Up to 35% Quieter under load
1600 G+
24.6dB
vs.
1600 G2
38dB
By combining quiet and long-lasting fan bearings with an optimized fan curve and a cleaner internal layout, the G+ power supply line-up reduces noise by up to 35%, compared to the G2 power supplies.
World leading warranty and support for 10 years
Specs At A Glance
Features
Gold Rated Efficiency
100% Japanese Capacitors
Fully Modular Design
A fully modular design allows cables to be removed from the power supply for ease of installation and removal. You can also leave off unncessary cables to reduce case clutter and maximize case airflow.
Tight voltage regulation (<1%)
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNOVA G+ power supplies provide up to 133A on a single rail!
Quiet and Durable Fan Bearings with EVGA ECO Mode
A high-quality 135mm fan gives the SuperNOVA G+ an excellent thermal and acoustic profile, and its high reliability ensures a long PSU lifetime. With EVGA ECO Mode, your power supply will remain silent under medium-to-low loads.
To protect and to serve
This PSU will cover your circuits with complete protection: OCP, OVP, OTP, OPP, SCP, and UVP.
Features
Specs
- OPP (Over Power Protection)
AC Input | 200-240V~, 9A, 60/50 Hz | ||||
MAX Output | 25A | 25A | 133A | 0.5A | 4A |
Combined | 150W | 1596W | 6W | 20W | |
Output Power | 1600W |
