evga geforce ® GTX 1660 Ti and 1660 gaming cards
zero compromise gaming
Completely Redesigned From the Ground Up:
  • New Hydro Dynamic Bearing (HDB) VGA Fans Offer Lower Noise and Longer Lifespan
  • New Fan Blades, Rotation Direction and Hub Designed for Quiet and Efficient Operation
  • EVGA Precision X1 Software Gives You New Ways to Overclock
The EVGA GeForce® GTX 1660 Ti and 1660 Graphics Cards are powered by the all-new NVIDIA Turing architecture to give you incredible new levels of gaming realism, speed, power efficiency, and immersion.
With the EVGA GeForce® GTX 1660 Ti and 1660 Graphics Cards you get the best gaming experience with next generation graphics performance, ice cold cooling and advanced overclocking features with the all new EVGA Precision X1 software.
NVIDIA TURING
GeForce® GTX 1660 Ti and 1660 graphics cards are powered by the Turing GPU architecture. This gives you higher performance compared to previous-generation graphics cards.
Hydro Dynamic Bearing Fans
First HDB fan on an NVIDIA graphics card optimizes airflow, increases cooling performance, and reduces fan noise by 15%, compared to more commonly-used sleeve-bearing fans on graphics cards. The special upraised 'E' pattern on the enlarged fan allows a further reduction in noise level by 4%.
Next-Gen Overclocking
With a brand new layout, completely new codebase, new features and more, the new EVGA Precision X1 software is faster, easier and better than ever. au.evga.com/px1
Your choice
EVGA GeForce® GTX 1660 Ti and 1660 graphics cards offer you more ways to keep your system cool than ever before. Offering a variety of fan choices, heatsink sizes, and cooling technologies, you can select the card that fits your system perfectly.
EVGA GeForce® GTX 1660 Ti and 1660 2 Slot Cards are longer, but allow for more airflow at slower speeds with two fans. Utilizing a smaller fan hub, these fans feature a longer blade to increase airflow while remaining quiet.
Need more horizontal space? EVGA GeForce® GTX 1660 and 1660 Ti 2.75 Slot Cards give you more front-to-back space without sacrificing cooling performance or acoustic noise. To enhance the cooling using a single fan, these cards use a taller fan hub specifically designed for the thicker heatsink to apply more force while keeping a lower noise profile.
1660 Ti
1660
Part Number Product Fans Cooling Type Boost Clock Cooler Size Power Phases
06G-P4-1267-KR EVGA GeForce® GTX 1660 Ti XC Ultra 2 Dual HDB Fans 1860 MHz 2 Slot 8
06G-P4-1263-KR EVGA GeForce® GTX 1660 Ti XC 1 Single HDB Fan 1845 MHz 2.75 Slot 6
06G-P4-1261-KR EVGA GeForce® GTX 1660 Ti XC Black 1 Single HDB Fan 1770 MHz 2.75 Slot 6
06G-P4-1167-KR EVGA GeForce® GTX 1660 XC Ultra 2 Dual HDB Fans 1845 MHz 2 Slot 7
06G-P4-1163-KR EVGA GeForce® GTX 1660 XC 1 Single HDB Fan 1830 MHz 2.75 Slot 5
06G-P4-1161-KR EVGA GeForce® GTX 1660 XC Black 1 Single HDB Fan 1785 MHz 2.75 Slot 5
06G-P4-1267
  • 1536 CUDA Cores
  • Boost Clock: 1860 MHz
  • Bus: PCIe 3.0
  • Memory Detail: 6144 MB GDDR6
  • Memory Bit Width: 192 Bit
  • Memory Clock: 12000 MHz
  • Memory Bandwidth: 288 GB/s
Key Features
  • NVIDIA® Ansel
  • NVIDIA® GeForce Experience
  • NVIDIA® Highlights
  • NVIDIA® G-SYNC™ Compatible
  • Game Ready Drivers
  • Microsoft® DirectX® 12 API, Vulkan API, OpenGL 4.6
  • HDCP 2.2
  • NVIDIA® GPU Boost™
  • Built for EVGA Precision X1
  • Supports NVIDIA NVENC Turing Encoder
06G-P4-1263
  • 1536 CUDA Cores
  • Boost Clock: 1845 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • HDCP 2.2
06G-P4-1261
  • 1536 CUDA Cores
  • Boost Clock: 1770 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • HDCP 2.2
06G-P4-1167
  • 1408 CUDA Cores
  • Bus: PCIe 3.0
  • Memory Detail: 6144 MB GDDR5
  • Memory Clock: 8000 MHz
  • Memory Bandwidth: 192 GB/s
Key Features
  • NVIDIA® Ansel
  • HDCP 2.2
06G-P4-1163
  • 1408 CUDA Cores
  • Boost Clock: 1830 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • HDCP 2.2
06G-P4-1161
  • 1408 CUDA Cores
  • Boost Clock: 1785 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • HDCP 2.2
