Header PSU
Header PSU
Header Warranty
Anything But Standard
Introducing the EVGA SuperNOVA GM line. Available in 450W, 550W, and 650W, these new power supplies are engineered to bring the power, prestige, and performance of EVGA's award-winning power supplies into an SFX-Standard form factor. Featuring 80 Plus Gold certified efficiency, fully-modular cables, and 100% Japanese capacitors on the Main PCB, the GM's cast a long shadow over its competition. Pint-size, affordable, and packed with everything you need, the EVGA SuperNOVA GM power supplies make short work of tight spaces.
FULLY MODULAR DESIGN
Use only the cables you need, reducing cable clutter and improving air flow.
Features 1
Features 2
SFX to ATX BRACKET ADAPTER INCLUDED
The GM power supplies were designed to power systems built in the smallest of PC cases, but are equally capable of powering systems built in a standard ATX form factor.
RELIABLE 100% JAPANESE CAPACITORS ON MAIN PCB
Get the most reliability and greatest performance with the use of the highest possible quality Japanese capacitors on the most critical system components.
Features 3
Features 4
92mm DURABLE DOUBLE-BALL BEARING FAN
A high-quality double-ball bearing fan gives the GM power supplies an excellent thermal and acoustic profile, and its high reliability ensures a long PSU lifetime.
whisper silent…
EVGA Auto ECO mode ensures that the power supply stays completely silent during low to medium loads. The fan does not spin until necessary, allowing for completely silent operation!
FEATURES
Specs 1
GOLD RATED EFFICIENCY
83 Plus certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical load, this power supply is 90% efficient or higher.
Specs 2
TIGHT VOLTAGE REGULATION(<2%)
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNova GM power supplies provide up to 54.1A on a single rail!
Specs 3
TO PROTECT AND TO SERVE
This PSU will cover your circuits with complete protection: OCP, OVP, OTP, OPP, SCP, and UVP.
Specs 4
DC TO DC CONVERTER
Voltage step-down for rock-solid power, stability, and minimal signal noise (for 3.3V and 5V)
Specs 5
SFX-STANDARD FORM FACTOR
The GM power supplies will fit all SFX-Standard form factor cases. With the included ATX adapter, these power supplies also support ATX case form factors.
WORLD LEADING
Warranty 7 years
World leading EVGA warranty and support for 7 years.
EVGA 650 GM
123-GM-0650
Features
  • Auto ECO Mode to ensure silent operation under low to medium loads with no configuration necessary
  • SFX-Standard Form Factor packs large power into a small space for compatibility with mITX cases and compact gaming systems
  • 100% Japanese Capacitors on Main PCB ensure long-term reliability
Specs
  • OPP (Over Power Protection)
AC Input 100-240 VAC, 9 - 4.5A, 50 - 60 Hz
DC Output +3.3V +5V +12V +5Vsb -12V
MAX Output 20A 20A 54.1A 2.5A 0.3A
TBA
Combined 100W 649.2W 12.5W 3.6W
Output Power 650W@40°C
EVGA 550 GM
123-GM-0550
Features
Specs
AC Input 100-240 VAC, 7.5 - 4A, 50 - 60 Hz
MAX Output 20A 20A 45.8A 2.5A 0.3A
549.6W
Combined 100W 549.6W 12W 3.6W
Output Power 550W@40°C
EVGA 450 GM
123-GM-0450
Features
Specs
AC Input 100-240 VAC, 6.5 - 3A, 50 - 60 Hz
MAX Output 20A 20A 37.5A 2.5A 0.3A
450W
Combined 100W 450W 12.5W 3.6W
Output Power 450W@40°C
450 GM
450 GM
550 GM
550 GM
650 GM
650 GM
