Introducing the EVGA BR Series of power supplies. Building upon our already great line of Bronze rated power supplies, we sought to make the improvements our customers asked for. Our BR Series are 80 PLUS Bronze certified, with 85% efficiency or higher under typical loads. Features a non-modular design with all black full sleeved cables for that high end aesthetic, 120mm sleeve bearing quiet fan, increased 3.3V/5V voltage stability, all backed by EVGA's World Leading Warranty and Support for 3 Years.
Standard ATX Form Factor
Will fit most mATX, EATX, HPTX, and XLATX cases.
All Black Sleeved Cable
Get that high end look while staying within your budget.
Features
Hard Lined Design
Hard lined design allows your cables to be attached to the power supply for ease of installation and removal. You can be ready to go right out of the box.
Long Sleeve Bearing Fan
A 120mm Long Life Sleeve Bearing fan results in quieter operation and a longer lifespan
Bronze Rated Efficiency
80 Plus certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical load this power supply is 85% efficient or higher.
DC to DC converter
Voltage step-down for rock-solid power stability and minimal signal noise. (For 3.3V and 5V)
Hardware Protection
While being silent, this entire series has a large single 12V rail, providing plenty of power to fuel all of your hardware. And lastly, because power without safety is pointless, a full suite of top tier circuit protections to keep you running strong and your hardware safe.
- OPP (Over Power Protection)
World Leading
World leading warranty and support for 3 Years.
Available for 450, 500, 600, 700 BR Models
Features
- Quiet and Intelligent Auto Fan for near-silent operation
- 3 Year Warranty
- Single +12V. Rail
Specs
AC Input | 100 - 240 VAC, 10/5A, 50 - 60 Hz | ||||
DC Output | +3.3V | +5V | +12V | +5Vsb | -12V |
MAX Output | 24A | 20A | 58.3 | 3A | 0.3A |
699.6W | |||||
Combined | 150W | 699.6W | 15W | 3.6W | |
Output Power | 700W @ +30C |
Features
- 3 Year Warranty
- Single +12V. Rail
Specs
MAX Output | 24A | 20A | 50A | 3A | 0.3A |
600W | |||||
Combined | 130W | 600W | 15W | 3.6W | |
Output Power | 600W @ +30C |
Features
- 3 Year Warranty
- Single +12V. Rail
Specs
AC Input | 100 - 240 VAC, 8/4A, 50 - 60 Hz | ||||
MAX Output | 20A | 20A | 41.7A | 3A | 0.3A |
500W | |||||
Combined | 120W | 500W | 15W | 3.6W | |
Output Power | 500W @ +30C |
Features
- 3 Year Warranty
- Single +12V. Rail
Specs
MAX Output | 20A | 20A | 37.5A | 3A | 0.3A |
450W | |||||
Combined | 120W | 450W | 15W | 3.6W | |
Output Power | 450W @ +30C |
