The G1+ PSU
Since its launch in 2013, the EVGA SuperNOVA G1 power supplies have been among the longest-lasting and best-performing power supplies on the market. Despite only a few changes over the years, it's only fitting that it's time for an upgrade. Enter the G1+, the new and improved fully-modular power supply line-up from EVGA with an 80+ Gold Efficiency rating.
Additionally, the G1+ power supplies feature a cleaner internal layout to increase airflow, a Variable Resistor module (to increase voltage stability), two DC to DC modules for more efficient power switching on all models, a full suite of power supply protections, and EVGA's World-Leading Global 10-Year Warranty on all G1+ power supplies.
1000/850 G1+
(180x150x85mm)
vs.
1000 G1
(200x150x85mm)
Shorter Length
750/650 G1+
(170x150x85mm)
vs.
750/650 G1
(180x150x85mm)
When it comes to building a system, even the smallest differences can make or break your build. Each G1+ power supply is between 10mm to 20mm shorter than its G1 counterpart, giving you more space without sacrificing quality.
Quieter and Longer-lasting fan
G1+ - 135mm Fluid
Dynamic Bearing Fan
vs.
G1 - 135 Dual
Ball Bearing Fan
Fluid Dynamic Bearings reduce the wear and tear on a fan's bearings, reduce noise, and feature a longer-lasting life than dual ball bearing fans.
Tighter 12v Load Regulation
1000 G1+
(0.52%)
vs.
1000 G1
(3.76%)
The G1+ features upgrades in many areas, including a single 12V. rail, 100% Japanese capacitors, VR module, and 2 DC to DC modules on all G1+ power supplies. This results in over 90% efficiency, 0.52%-0.62% 12V. load regulation, and stable power to all connected devices.
Up to 22% Quieter under load
1000 G1+
(24.2dB)
vs.
1000 G1
(30dB)
Combining its Fluid Dynamic Bearing fan, along with a clean internal layout, the G1+ power supply line-up reduces noise by up to 22%, compared to the G1 power supplies.
World leading warranty and support for 10 years
Specs At A Glance
Features
Gold Rated Efficiency
100% Japanese Capacitors
Fully Modular Design
A fully modular design allows cables to be removed from the power supply for ease of installation and removal. You can also leave off unncessary cables to reduce case clutter and maximize case airflow.
Tight voltage regulation (<1%)
A single +12V rail offers the best power output, rail stability and compatibility with the latest hardware. EVGA SuperNOVA G1+ power supplies provide up to 83A on a single rail!
Fluid dynamic bearing fan
A high-quality 135mm fluid dynamic bearing fan gives the SuperNOVA G1+ an excellent thermal and acoustic profile, and its high reliability ensures a long PSU lifetime.
To protect and to serve
This PSU will cover your circuits with complete protection: OCP, OVP, OTP, OOP, SCP, and UVP.
Features
Specs
- OPP (Over Power Protection)
AC Input | 100-240 VAC, 15-8A, 50 - 60 Hz | ||||
DC Output | +3.3V | +5V | +12V | +5Vsb | -12V |
MAX Output | 24A | 24A | 83.3A | 3.0A | 0.5A |
999.6W | |||||
Combined | 120W | 999.6W | 15W | 6W | |
Output Power | 1000W@50°C |
Features
Specs
AC Input | 100-240 VAC, 12-5A, 50 - 60 Hz | ||||
MAX Output | 24A | 24A | 70.8A | 3.0A | 0.5A |
849.6W | |||||
Combined | 120W | 849.6W | 15W | 6W | |
Output Power | 850W@50°C |
Features
Specs
AC Input | 100-240 VAC, 10-5A, 50 - 60 Hz | ||||
MAX Output | 24A | 24A | 62.4A | 3.0A | 0.3A |
748.8W | |||||
Combined | 120W | 748.8W | 15W | 3.6W | |
Output Power | 750W@50°C |
Features
Specs
MAX Output | 24A | 24A | 54A | 3.0A | 0.3A |
648W | |||||
Combined | 120W | 648W | 15W | 3.6W | |
Output Power | 650W@50°C |
