Ultimate GeForce
The EVGA GeForce® GTX 1080 Ti uses NVIDIA's new flagship gaming GPU, based on the NVIDIA Pascal™ architecture. The latest addition to the ultimate gaming platform, this card is packed with extreme gaming horsepower, next-gen 11 Gbps GDDR5X memory, and a massive 11 GB frame buffer. #GameReady
View Products
About EVGA iCX Technology
Featuring a total of 11 global patents (pending and granted), iCX from EVGA is efficiency perfected. With 9 additional sensors embedded on the PCB, a newly designed die-cast baseplate and backplate, purposefully-directed airflow chambers, and full control using EVGA Precision XOC, EVGA's iCX is the very definition of Interactive Cooling.
EVGA iCX
The patented EVGA iCX is comprised of two main components - EVGA iCX Cooling and EVGA iCX Technology. Select EVGA GeForce GTX 1080 Ti graphics cards are built using EVGA iCX Cooling, which delivers industry-leading cooling performance. To take full advantage of iCX Cooling, select EVGA GeForce GTX 1080 Ti graphics cards are built with iCX Technology to monitor temperatures and communicate dynamically with iCX Cooling to give you Peace of Mind Gaming.
EVGA iCX Cooling
EVGA iCX Cooling was built from the ground-up to reimagine how every area of a graphics card can improve cooling performance. iCX Cooling begins with a form-fitting die-cast baseplate and backplate, which touch all vital components and uses an interlaced pin fin design to remove more heat from components. The aerodynamically-designed heatsink contacts the baseplate in multiple areas, using a series of pin holes and half-open fins to direct air over the graphics card. EVGA GTX 1080 Ti graphics cards with iCX Cooling include a safety fuse to protect your card and system. iCX Cooling can be further controlled by using EVGA Precision XOC.
EVGA iCX Technology
EVGA iCX Technology takes iCX Cooling to a new level. iCX Technology incorporates 9 additional thermal sensors on the graphics card PCB, which monitor the GPU, the Power, and Memory areas of the graphics card. The iCX Technology monitoring is used to dynamically direct the fans asynchronously to allow iCX Cooling to increase airflow wherever it's needed most. iCX Technology further includes a safety fuse to protect your card and system. EVGA iCX Technology can be further monitored and controlled through EVGA Precision XOC to truly give you Peace of Mind Gaming!
iCX Technology | iCX Cooling | ||
EVGA GTX 1080 Ti Models | FTW3 | SC2 | SC Black Edition |
Part Numbers | 11G-P4-6696 | 11G-P4-6593 | 11G-P4-6393 |
iCX Features | |||
iCX Technology | |||
iCX Cooling | |||
RGB LED G/P/M | |||
Cooler LED | RGB | RGB | White |
Fan # | 3 | 2 | 2 |
Asynchronous Fans | |||
Safety Fuse | |||
# of BIOSes | 2 | 1 | 1 |
Phase Design | 10+2 | 7+2 | 7+2 |
PCI-E Power Connectors | 8+8 | 6+8 | 6+8 |
Display Outputs | 3xDP, HDMI, DVI-D (physical) | 3xDP, HDMI, DVI-D (physical) | 3xDP, HDMI, DVI-D (physical) |
GTX 1080 Ti FTW3
GTX 1080 Ti SC2
GTX 1080 Ti SC Black Edition
