Header
Introducing EVGA Frostbite 2 Thermal Grease, the next generation in thermal interface material. Designed to deliver a highly-efficient heat transfer under any workload, Frostbite 2 is easy to apply to ensure optimal thermal contact between your CPU or GPU and its heatsink. Whether you’re air cooling, water cooling, gaming or overclocking, EVGA Frostbite 2 Thermal Grease will keep your temperatures on ice.
Frostbite
Frostbite
Chart
Features
  • Easy to Apply
  • Great Thermal Conductivity
  • Built for High Performance
400-TG-TM01-BR
Specs and Features
  • Specific Gravity (g/cm³) 3
  • Breakdown Voltage (V/mil) 250
  • Color Grey
  • Weight 2.5 Gram Syringe
  • Operating Temperature -40~180 degrees Celsius
  • Easy to Apply
