Back To Top
Built For The Win
Introducing the EVGA GeForce GTX 980 Ti FTW. Accelerated by the groundbreaking NVIDIA Maxwell architecture, the EVGA GeForce GTX 980 Ti FTW ups the game with dual 8-Pin Power inputs, 8+2 Phase Power Design, Dual BIOSes and an included EVGA backplate. Not to mention this card packs 2816 NVIDIA CUDA Cores and 6GB of GDDR5 memory, giving you the horsepower to drive whatever comes next. In fact, the EVGA GeForce GTX 980 Ti FTW provides over 3x the performance and 3x the memory of previous-generation cards*.
This card also features EVGA ACX 2.0+ cooling technology. EVGA ACX 2.0+ brings new features to the award winning EVGA ACX 2.0 cooling technology. A memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 13%, and optimized Straight Heat Pipes (SHP) additionally reduce GPU temperature by 5C. ACX 2.0+ coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
*GeForce GTX 680
8+2 Power Phases
Built for Overclocking with an Extra +25W of Power
EVGA ACX 2.0+ Cooling
Remark:
* Versus Competitors' Dual Fan Solution.
** When GPU Temperature < 60°C
*** Versus Reference Fan
Why Double Ball Bearings?
EVGA ACX 2.0+ Means Better Overclocking
BUILT WITH 6GB OF HIGH PERFORMANCE GDDR5 MEMORY
6GB of High Performance memory running at extreme clockspeeds giving you access to higher texture qualities in games, improved 4K gaming performance and optimized for the next generation of gaming.
06G-P4-4996
  • 2816 CUDA Cores
  • Base Clock: 1190 MHz
  • Boost Clock: 1291 MHz
  • Bus: PCIe 3.0
  • Memory Detail: 6144 MB GDDR5
  • Memory Bit Width: 384 Bit
  • Memory Clock: 7010 MHz
  • Memory Speed: 0.28 ns
Key Features
  • 8+2 Phase PWM
  • Dual BIOS Support
  • NVIDIA MFAA Technology
  • NVIDIA GameWorks Technology
  • NVIDIA G-SYNC Ready
  • NVIDIA GPU Boost 2.0
  • NVIDIA Surround Technology
  • NVIDIA SLI Ready
  • OpenCL Support
  • PCI Express 3.0 x16
  • EVGA ACX 2.0 Cooling
  • dB Inverter
  • Memory MOSFET Cooling Plate
  • Straight Heat Pipes
  • Preinstalled Backplate
  • OpenGL 4.6 Support
EVGA GeForce GTX 980 Ti FTW Comparison Chart
Introducing EVGA PrecisionX 16 version 5.3.5 with full support for Microsoft DirectX 12 OSD support. This latest version of EVGA PrecisionX adds new features, overclocking support, functionality, and full support for the upcoming Microsoft DirectX 12 API. Download it for free today!
Key Features
  • Full support for Microsoft DirectX 12 API
  • Redesigned OSD interface with RGB color support
  • Available on Steam or as a separate download
Launch Precision Site
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 980 Ti FTW vitals. Learn more and download it here.
Key Features
  • Built-in stress tester to find and report artifacts
  • Benchmark function to quickly test your performance
  • CPU Burn In Module
  • Built-in log functionality
Launch OC Scanner Site
