Back To Top
EVGA GeForce GTX 950 Cards
Advanced Gaming
The EVGA GeForce GTX 950 features a true gaming GPU designed for every PC gamer. It’s built to the exact specifications of the GeForce GTX family and powered by NVIDIA Maxwell – the most advanced GPU architecture ever created – to deliver 3x the performance of previous-generation cards.* More powerful than any console, this card delivers a truly interactive, cinematic experience in the latest games with advanced effects driven by NVIDIA GameWorks and DirectX 12.
The EVGA GeForce GTX 950 lineup also features the new EVGA ACX 2.0 Cooling for superior cooling performance and power savings with swept fan blades, double ball bearings and an extreme low power motor, delivering more airflow with less power, unlocking additional power for the GPU.
Ready to get real about gaming? Experience the performance of the new EVGA GeForce GTX 950 today.
*GeForce GTX 650
Full HD Performance
Maxwell's exceptional performance and efficiency means you can transform your basic PC into a modern gaming rig that can play the latest games at 1080p.
GeForce GTX 950
GeForce GTX 650
Game Comparison
Remark:
* Versus Competitors' Dual Fan Solution.
** When GPU Temperature < 60°C
*** Versus Reference Fan
Why Double Ball Bearings?
EVGA ACX 2.0 fans use double ball bearings, which offer 4X longer lifespan than the sleeve bearing fans used by competitors. The oil that is used in sleeve bearing fans makes them vulnerable and prone to failure after time when the oil dries up. Upgrade to EVGA ACX 2.0 and your card will go the distance!
EVGA ACX 2.0 Means Better Overclocking
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum "power target" takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX 2.0 coolers use more than 4X lower power than competitors allowing for better and more stable overclocks. In some cases, just a few watts of additional power for the card can provide an additional headroom of up to +25MHz higher GPU or +350MHz memory frequency!
02G-P4-2958
EVGA GeForce GTX 950 FTW
  • 768 CUDA Cores
  • Base Clock: 1203 MHz
  • Boost Clock: 1405 MHz
  • Bus: PCIe 3.0
  • 2-way SLI Ready
  • Memory Bit Width: 128 Bit
  • Memory Clock: 6610 MHz
  • Memory Speed: 0.30 ns
  • Memory Bandwidth: 105.76 GB/s
Key Features
  • EVGA Backplate
  • NVIDIA MFAA Technology
  • NVIDIA GameWorks Technology
  • NVIDIA G-SYNC Ready
  • NVIDIA GPU Boost 2.0
  • NVIDIA Surround Technology
  • NVIDIA SLI Ready
  • OpenGL 4.4 Support
  • OpenCL Support
  • PCI Express 3.0 x16
  • EVGA ACX 2.0 Cooling
  • Quick Switch Dual BIOS
  • dB Inverter
  • Optimized Power Target
  • Straight Heat Pipes
02G-P4-2957
EVGA GeForce GTX 950 SSC
  • 768 CUDA Cores
  • Base Clock: 1190 MHz
  • Boost Clock: 1393 MHz
  • Bus: PCIe 3.0
  • 2-way SLI Ready
Key Features
  • NVIDIA SLI Ready
  • OpenCL Support
  • dB Inverter
02G-P4-2956
EVGA GeForce GTX 950 SC+
  • 768 CUDA Cores
  • Base Clock: 1165 MHz
  • Boost Clock: 1355 MHz
  • Bus: PCIe 3.0
  • 2-way SLI Ready
Key Features
  • NVIDIA SLI Ready
  • OpenCL Support
  • dB Inverter
02G-P4-2951
  • 768 CUDA Cores
  • Base Clock: 1152 MHz
  • Boost Clock: 1342 MHz
  • Bus: PCIe 3.0
  • 2-way SLI Ready
Key Features
  • NVIDIA SLI Ready
  • OpenCL Support
EVGA GeForce GTX 950 Comparison Chart
Introducing EVGA PrecisionX 16 version 5.3.5 with full support for Microsoft DirectX 12 OSD support. This latest version of EVGA PrecisionX adds new features, overclocking support, functionality, and full support for the upcoming Microsoft DirectX 12 API. Download it for free today!
Key Features
  • Full support for Microsoft DirectX 12 API
  • Redesigned OSD interface with RGB color support
  • Available on Steam or as a separate download
Launch Precision Site
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 950 vitals. Learn more and download it here.
Key Features
  • Built-in stress tester to find and report artifacts
  • Benchmark function to quickly test your performance
  • CPU Burn In Module
  • Built-in log functionality
Launch OC Scanner Site
