EVGA GeForce GTX 1050 Gaming Perfection with EVGA Precision XOC NVIDIA GeForce GTX GAME READY
EVGA GeForce GTX 1050 Ti & 1050
The EVGA GeForce GTX 1050 Ti & 1050 hit the perfect spot for that upgrade you know you need, but at the price you want! With the latest NVIDIA Pascal architecture, the 4GB GTX 1050 Ti displays stunning visuals and great performance at 1080p HD+, while the 2GB GTX 1050 will break through any obstacle at 1080p.
Installing a EVGA GeForce GTX 1050 Ti and GTX 1050 card gives you the power to take on today’s next-gen titles in full 1080p HD – with room to spare. These cards give you a choice of memory sizes, cooling options, factory overclocks, and power options to fit every need and every system. Of course, no GTX card would be complete without essential gaming technologies, such as NVIDIA GameStream, G-Sync, and GeForce Experience.
If you’ve been waiting for that card that gives you the performance to take back the competitive edge, but without taking out your wallet, then the GTX 1050 Ti & 1050 are the cards for you!
Small Size
Big
Performance
EVGA Precision XOC unlocks the power of Pascal
The next generation of EVGA PrecisionX has arrived with EVGA Precision XOC. This new version of Precision is built for the new NVIDIA Pascal architecture and combines the best of EVGA Precision and EVGA OC Scanner to give you never before seen overclocking features and built-in automatic overclock tuning.
EVGA Precision XOC
Standard Overclock Mode
Pascal Linear
Pascal Linear
Pascal Manual
Pascal Manual
EVGA Precision XOC
Built-In Automatic Tuning
Define Your Game With EVGA Precision XOC
Why double ball bearings?
Run longer, play longer with EVGA ACX 3.0
EVGA ACX means better overclocking
Did you know that power consumption of the fans can directly affect your maximum overclock? The maximum "power target" takes into account the fan power consumption, meaning the lower the power consumption from the fan, the more power available for the card. EVGA ACX coolers use more than 4X lower power than competitors allowing for better and more stable overclocks.
Lower fan power = More power for overclocking
EVGA ACX 3.0 EVGA GeForce GTX 1050 Ti
04G-P4-6258
EVGA GeForce GTX 1050 Ti FTW
  • 768 CUDA Cores
  • Base Clock: 1379 MHz
  • Boost Clock: 1493 MHz
  • Bus: PCIe 3.0
  • Memory Bit Width: 128 Bit
  • Memory Clock: 7008 MHz
  • Memory Speed: 0.28 ns
  • Memory Bandwidth: 112.16 GB/s
Key Features
  • NVIDIA G-SYNC Ready
  • OpenGL 4.6 Support
  • NVIDIA® Ansel
  • NVIDIA GPU Boost 3.0
  • Microsoft DirectX 12 API
  • Vulkan API
  • PCI Express 3.0
  • EVGA ACX 3.0 Cooling
04G-P4-6256
EVGA GeForce GTX 1050 Ti FTW DT
  • 768 CUDA Cores
  • Base Clock: 1290 MHz
  • Boost Clock: 1392 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
04G-P4-6255
EVGA GeForce GTX 1050 Ti SSC
  • 768 CUDA Cores
  • Base Clock: 1366 MHz
  • Boost Clock: 1480 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
04G-P4-6253
EVGA GeForce GTX 1050 Ti SC
  • 768 CUDA Cores
  • Base Clock: 1354 MHz
  • Boost Clock: 1468 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
04G-P4-6251
  • 768 CUDA Cores
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
02G-P4-6157
EVGA GeForce GTX 1050 FTW
  • 640 CUDA Cores
  • Base Clock: 1442 MHz
  • Boost Clock: 1556 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
02G-P4-6155
EVGA GeForce GTX 1050 FTW DT
  • 640 CUDA Cores
  • Boost Clock: 1455 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
02G-P4-6154
EVGA GeForce GTX 1050 SSC
  • 640 CUDA Cores
  • Base Clock: 1430 MHz
  • Boost Clock: 1544 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
02G-P4-6152
EVGA GeForce GTX 1050 SC
  • 640 CUDA Cores
  • Base Clock: 1417 MHz
  • Boost Clock: 1531 MHz
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
02G-P4-6150
  • 640 CUDA Cores
  • Bus: PCIe 3.0
Key Features
  • NVIDIA® Ansel
  • Vulkan API
  • PCI Express 3.0
