The Ultimate Graphics Card Meets Ultimate Cooling
Introducing the EVGA GeForce GTX TITAN X HYBRID, an “all in one” water cooling solution that significantly lowers the GPU operating temperature. Best of all? The water cooler is completely self-contained, with an included 120mm radiator and fan. No filling, no custom tubing, no maintenance. Just plug in and play! The EVGA GeForce GTX TITAN X HYBRID is available as a complete unit, or upgrade kit.
The NVIDIA GeForce GTX TITAN X GPU combines the technologies and performance of the new NVIDIA Maxwell architecture in the fastest and most advanced graphics card on the planet. This incredible GPU delivers unrivaled graphics, acoustic, thermal and power-efficient performance. The most demanding enthusiast can now experience extreme resolutions up to 4K-and beyond.
- 3072 CUDA Cores
- Base Clock: 1152 MHz
- Boost Clock: 1241 MHz
- Memory Detail: 12288 MB GDDR5
- Memory Bit Width: 384 Bit
- Memory Clock: 7010 MHz
- Memory Speed: 0.28 ns
Key Features
- NVIDIA MFAA Technology
- NVIDIA GameWorks Technology
- NVIDIA G-SYNC Ready
- NVIDIA GPU Boost 2.0
- NVIDIA Surround Technology
- NVIDIA SLI Ready
- OpenGL 4.4 Support
- OpenCL Support
- PCI Express 3.0 x16
Key Features
- Built in 120mm radiator and fan helps dissipate the heat keeping the GPU as cool as possible. Fan can also be swapped or customized.
- VRM and Memory cooling solution separated from GPU, allowing for the lowest GPU temperatures, and efficient VRM and Memory cooling.
- Compatible with all "reference" style graphics cards.
Key Features
- Temperature Target Control
- Pixel Clock Overclocking
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX TITAN X HYBRID vitals. Learn more and download it here.
Key Features
- CPU Burn In Module
- Built-in log functionality
