Play The Future
Introducing the EVGA GeForce GTX 980 Ti. Accelerated by the groundbreaking NVIDIA Maxwell architecture, GTX 980 Ti delivers an unbeatable 4K and virtual reality experience. With 2816 NVIDIA CUDA Cores and 6GB of GDDR5 memory, it has the horsepower to drive whatever comes next. In fact, the EVGA GeForce GTX 980 Ti provides 3x the performance and 3x the memory of previous-generation cards*. You can now take on even the most challenging games at high settings for a smooth, ultra high-definition, 4K experience.
These cards also feature EVGA ACX 2.0+ cooling technology. EVGA ACX 2.0+ brings new features to the award winning EVGA ACX 2.0 cooling technology. A memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 13%, and optimized Straight Heat Pipes (SHP) additionally reduce GPU temperature by 5C. ACX 2.0+ coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
*GeForce GTX 680
Why Double Ball Bearings?
EVGA ACX 2.0+ Means Better Overclocking
BUILT WITH 6GB OF HIGH PERFORMANCE GDDR5 MEMORY
6GB of High Performance memory running at extreme clockspeeds giving you access to higher texture qualities in games, improved 4K gaming performance and optimized for the next generation of gaming.
Get Cooler with EVGA HYBRID and HYDRO Coolers
Looking for something even cooler? Achieve gaming bliss when paired up with an EVGA HYBRID or Hydro water cooler.
- 2816 CUDA Cores
- Base Clock: 1140 MHz
- Boost Clock: 1228 MHz
- Memory Bit Width: 384 Bit
- Memory Clock: 7010 MHz
- Memory Speed: 0.28 ns
Key Features
- NVIDIA MFAA Technology
- NVIDIA GameWorks Technology
- NVIDIA G-SYNC Ready
- NVIDIA GPU Boost 2.0
- NVIDIA Surround Technology
- NVIDIA SLI Ready
- OpenCL Support
- PCI Express 3.0 x16
- OpenGL 4.6 Support
- 2816 CUDA Cores
Key Features
- NVIDIA SLI Ready
- OpenCL Support
- 2816 CUDA Cores
- Base Clock: 1190 MHz
- Boost Clock: 1291 MHz
Key Features
- EVGA EVBot Support
- Dual BIOS Support
- NVIDIA SLI Ready
- OpenCL Support
- EVGA ACX 2.0 Cooling
- dB Inverter
- Memory MOSFET Cooling Plate
- Straight Heat Pipes
- Preinstalled Backplate
- 14+3 Power Phases
- 2816 CUDA Cores
- Base Clock: 1102 MHz
- Boost Clock: 1190 MHz
Key Features
- NVIDIA SLI Ready
- OpenCL Support
- dB Inverter
- 2816 CUDA Cores
Key Features
- NVIDIA SLI Ready
- OpenCL Support
- dB Inverter
- 2816 CUDA Cores
- Base Clock: 1000 MHz
- Boost Clock: 1076 MHz
Key Features
- NVIDIA SLI Ready
- OpenCL Support
- dB Inverter
- 2816 CUDA Cores
Key Features
- NVIDIA SLI Ready
- OpenCL Support
- 2816 CUDA Cores
Key Features
- OpenCL Support
- NVIDIA SLI Ready
- NVIDIA G-SYNC
EVGA GeForce GTX 980 Ti Comparison Chart
Introducing EVGA PrecisionX 16 version 5.3.5 with full support for Microsoft DirectX 12 OSD support. This latest version of EVGA PrecisionX adds new features, overclocking support, functionality, and full support for the upcoming Microsoft DirectX 12 API. Download it for free today!
Key Features
- Full support for Microsoft DirectX 12 API
- Redesigned OSD interface with RGB color support
- Available on Steam or as a separate download
EVGA OC Scanner X – Featuring a brand new look and layout, this popular application has been updated to show all of the GeForce GTX 980 Ti vitals. Learn more and download it here.
Key Features
- CPU Burn In Module
- Built-in log functionality
